SimplyDubs
VW and loving it...
- Messages
- 934
- Vehicle
- N/A
Hi there team,
Looks like I may have an issue with the wiring for the number plate lights.
Lights went intermittent, would come on if tapped gently.
I know it's not the terminals corroded (common problem) as I'm getting no volts to the connections. (Using multimeter)... I've checked the fuses
So question is, does anyone know the procedure for getting to the wiring in the tailgate or removing the handle trim that houses the number plate lights?
Suspect it's a case of removing all the rear trim panels which will be a pain, but if anyone has the full sequence, it would be appreciated.
Thanks in advance.
Mark
Thanks in advance.
Mark
