AlexD
Hello everyone,
I have an issue about the roof tent and actually for the entire central control unit.
Long story short, seeing the behavior from the last 2 times staying in the camping without aux power supply, only the batteries and the solar panel, the control unit is showing that message with roof open( 1000 fault in diagnosis) , stopping the fridge + aux heater and also the inverter is not working anymore.
Last time when this happens, I have closed the roof manually, by releasing the pressure in the hidraulic system of the roof. Fault 1000 was still present . I couldn’t delete this, until I have disconnect both leisure batteries: the one from the drawer and the one under driver seat( living in Germany, so driving on the right side of the road).
I have 2 questions about this:
1. Why should be the reason of this failure 1000 appears, supposed that the batteries are getting dry…
2. I would like to locate the fuse of the central control unit… I have try already behind the bottle holder … no chance to reset it ( @Loz I see you active on this topic)
Currently in a camping in Croatia.
Thanks for helping
Thanks for helping
