You can if you remove the rear shelf instead, if you then slide the 5th seat to join up with the bed you end up with a full length bed on the side the 5th seat is & a shorter bed on the otherside about 5ft long.Hello
When an Ocean has 5 seats, is it possible to lay the bed out without taking the 5th seat out?
Thanks.
