Ch1pbutty
Agree but PV's make good sense regardless of whether or not you own an EV. The battery is an expense, but then it does then give you access to a cheaper tariff for your home. Before the increase last Friday our electricity was around 23p per kw, so even higher now (but will be switching once the panels get fitted). Although the Powerwall will store 13.5kw, under current network regulations it comes with a pre-set output of 3.6kw, balance goes to the national grid. The battery just means you sell surplus at 11p per kw and buy it back at same price when you need it.Well yes but that's after you've paid out about £10,000 for a Tesla Powerwall plus several thousand more for the PVs. Also, that pricing scheme only covers up to £9,500 kWh per year, which is less than the average household uses for all energy uses.
As far as charging an EV is concerned, well okay but a keep in mind a Tesla car battery takes 100 kWh (okay you don't necessarily need to recharge it fully each day if you're only doing short distances) whereas a Powerwall stores only 13.5 kWh and your rooftop PVs will even then only be able to replenish that on a sunny summer day. So unless you're only pottering around locally your £15k Solar+Powerwall investment isn't even going to be able to cover your car usage (and if you are only pottering around locally, say 5,000 miles a year in a little ICE car, your petrol would only be costing around £1,000 a year anyway even at £2 a gallon).
(I'm not anti-solar, nor anti-EV, am planning to install panels at home later this year after heat pump has also gone in, however let's not kid ourselves that it makes economic sense at the moment.)
To cover 5,000 miles charging at a Tesla charger is £275 approx (ie - think at the moment we get 200 'real' miles for about £11; that said we have needed to charge away from the house twice in 5000miles / 6 months). We just plug it in at home every now & again.
Energy prices will continue to rise, so happy to outlay now to have a quicker payback.
(But that said I still can't see me ever buying an electric Cali if it ever comes out, will stick with my old diesel one! + EV as 2nd car)
