Rented a 102 PS last August - not enough grunt for me. You felt you were working the poor thing to oblivion!Base vehicle a 102 manual 5 speed...
I do like the zip opening pop top, great for event viewing!
What about VW's body corrosion warranty? The converter has to cut the roof panel out...It looks interesting. However it's difficult to offer an opinion without seeing in the flesh.
Until then my only comments are:
It's nice to see the sliding door on the N/S.
Seems to be a good spec.
Even though IMO it's a bit pricey for a 102ps manual base vehicle.
I would be interested in how the roof structure compares to a Cali.
I would also be concerned about depreciation compared to a Cali.
I am delighted to see another British company entering the conversion market place.
The van, the base vehicle, have a pressed steel roof, not aluminium.What about VW's body corrosion warranty? The converter has to cut the roof panel out...
Yes I realise that but the converter has to cut that out exposing raw edges of steel. VW warranty still in place? I think not!The van, the base vehicle, have a pressed steel roof, not aluminium.
Still better than a converter who has cut the roof off and.........well your guess is a good as mine!Yeah, it's like the vw body / paint warranty is really worth having.......
Good point. I don't know what would happen with the VW warranty but as there's less than zero chance of me every buying one, I don't think that will be an issue.What about VW's body corrosion warranty? The converter has to cut the roof panel out...
The Warranty is still in place if the Converter is a VW Approved Converter. They can purchase brand new base vehicles from VW for conversion and the full VW 3 year warranty is in force. The trouble is they are normally limited as to which base vehicles they can purchase.Yes I realise that but the converter has to cut that out exposing raw edges of steel. VW warranty still in place? I think not!
Wow! This Cali world is complex and full of unexpected discoveries......The Warranty is still in place if the Converter is a VW Approved Converter. They can purchase brand new base vehicles from VW for conversion and the full VW 3 year warranty is in force. The trouble is they are normally limited as to which base vehicles they can purchase.
When I enqired some years ago VW would not supply the 180 biturbo . I could purchase a 180 and get it converted but the Warranty would not be the same, but then I found that going down that pathway, with a 180 4Motion, the conversion made the vehicle overweight when fully loaded.
Think I'd want the kitchen units edge banded and not reimo knock on trim. Nice conversion but not 5
when they cut the roof hole out will it be as ridgid as a cali
When they cut the roof hole out will it be as ridgid as a cali body, or rattle and squeak.The van, the base vehicle, have a pressed steel roof, not aluminium.
They do insert strengtheners but some do complain of noise etc: but whether that is to do with the actual components or the fitting I do not know.When they cut the roof hole out will it be as ridgid as a cali body, or rattle and squeak.
