Problem with parking sensrs
inthemidnighthour
inthemidnighthour
Norwich
T6.1 Ocean 199
Hi All
has anyone had or solved the following issue
the parking sensor display no longer displays on the radio
the parking sensor button flashes
and continuous tone emitted
this is the second time this has happened the first time it seemed to clear after a while but this has now been a couple of weeks
any ideas help would be gratefully received
thanks dave and lisa :thumb
Sounds like a failed/damaged parking sensor which would cause the button to flash and a constant tone.
cheers
I've had the same and took it to VW. They said it was a failed rear parking sensor. Needs replacing, will be approx £150!
Hope that helps?
Jane
One of our rear sensors stopped working and we had the constant beep to tell us. We did nothing with it, except park the van in hot sun last Sunday and hey presto it works again - it is lucky that I never want to reverse when it is raining...
Steve
Been in to VW and they have replaced one of the rear sensors
ours was the same it worked for a while then just a constant tone very intermittent
dave and lisa
