Problem with towbar electrics
Dave_T
Dave_T
T5 SE 140
Hi,
I've got a weird issue with my towbar electrics on my 2012 California.
It all used to work fine but there's been a recent problem where the trailer lighting board only partially works
Right indicator works
Left indicator doesn't, but when that happens the dashboard ticking runs double speed.
Brake lights & normal lights don't work.
I also get a yellow warning light on the dashboard
The towbar and electric harness is all VW fitted. This all used to work just fine.
I have tested with a different light board, but I get exactly the same problem, so it's a van problem not a light board problem
Any ideas?
Dave
Hi,
Any ideas?
Dave
Most common and probable cause is corrosion within the vehicle socket.
If that is the case then easily replaced.
L
Californiaman
Californiaman
andyinluton
Phil Hall
Phil Hall
marshian70
marshian70
marshian70
timber
9K
B J G
B J G
