![kurienp](/data/avatars/m/15/15045.jpg?1583881050)
kurienp
Ok, "not planned for expense" time, so need inputs from the collective minds on here.
AC not cooling, problem identified as pipe to rear AC corroded and so has lost all gas hence AC not cooling. All good till here ...
... until you hear the price of replacing the pipe - 198 GBP per pipe (I think I heard that right).
While I wait for a formal quote, would someone here know if it possible to repair a metal AC cooling pipe or is it always a replacement?
Also, I see that there are two kinds of pipes - metal and rubber. I guess when he said corroded, that would be the metal pipe. That is just a small section of the pipe and so should not cost £198, unless he is considering replacing all the pipes from front to back.
Inputs appreciated. Will keep all updated.
