Rear wiper Cali Ocean 2019
G
gcawood
The rear wiper isn’t working
I have found the fuse and it had gone so I replaced it.
It’s difficult to tell if I got it in the right place holder but I am fairly sure. The wiper still doesn’t work. Any help would be appreciated
George
George
The fuse blew for a reason so the fault could be anywhere in the circuit, switch, wiring or wiper motor. However things aren’t quit so simple because , I believe, the BCM , vehicle computer, is also involved.
As you are still in warranty a visit to the Dealership might be the easiest way to sort things.
Otherwise, a Diagnostic screen with VCDS or an OBD dongle like Carista or OBDeleven.
Take a note of any Diagnostic codes relating to wipers and then clear them. This might reset wipers.
If no codes, check fuse again. Then it becomes more difficult as you really need to use a multimeter to check circuit continuity to the rear wiper and check that you are getting 12v at wiper.
Many thanks for your help
George
How do I download the fuse layout plan please?
The Downloads are in the Resources section and available to VIP members.
