pjm-84
- Messages
- 2,532
- Vehicle
- T5 SE 180
My rears swapped at 73,000 k + pads ,some scouring on inner face . My decision to change. Front changed at 91,000 due to some circular ridging and worn pads.
Now on my third set at the rear at 72k. Swapped the fronts out at 53k for Brembos and they still look as newMy rears swapped at 73,000 k + pads ,some scouring on inner face . My decision to change. Front changed at 91,000 due to some circular ridging and worn pads.
Use it or lose it.
Yes. I believe they were standard on my 4Motion.@WG do you have the big brake front disc option?
Wondering if this is a side effect of the 340mm front stopping power over the standard 308
Discs normally good for 80/120K miles, Pads 30/70K Miles; Depending on driving style.Just paid £265 for fronts and £327 for rears at an independent VW specialist, so £592 in total. Genuine VW parts and same warranty. At 65K miles this is the third set on the rears an second set on front. So getting between 20k to 30k miles per set. The discs seem to wear at the same rate as the pads, which amazes me.
Pads on mine half worn...Discs normally good for 80/120K miles, Pads 30/70K Miles; Depending on driving style.
Your discs should be lasting far longer, unless you are braking on worn pads which will score the disc...but you would hear a grinding noise of this was the case.
@pjm-84 I had my rear discs and pads changed roughly 9000 miles ago for genuine VW and they are now starting to score on the inside. Like you the majority of my mileage has been mostly on motorways/peage. Planning to change to ATE when the pads are worn.
Listers Droitwich are £100+ more than that todayRecently had new rear discs and pads at 47,000 miles. £400 at South Hereford VW Van centre.
