H
Hotel California
As the bendy rooflight on my 2012 T5 is due to break at some point and the fact there's no 12V socket within reach when you lie in the pop-top to charge a phone at night within hands reach , i had the idea to take away the bendy light and put a cigaretlighter/12V socket in place.
The bendy light is still in perfect condition and the wife uses it to read upstaires , still i been thinkin about this operation quite some time , she also uses a headlight (Petzl) to read and there are 12V bendy lights with a sigaret plug on the market witch i now will purchase (led light)
Had the light allready taken out to check things out and got myself a 12v socket some time ago.
Time to get the tools out!
Unscrew the bendy light.
As you can see no way you can reach in to unplug the wire
Tryed to remove a plastic trim to the left as i was thinking it would give acces ....
Gently squize a flat screwdriver under it and lift up...
No use as there's no way getting in thru there
At least now i know on what day my Cali has been painted...
So you need to remove the B-pilar trim in witch the seatbelt disappears
It comes off with a firm pull
That way you can reach in from behind to unplug the bendy light
Now you can take the light out
I did not wanted to cut of the feedplug from the cable so used the plug from the bendy light to extend it connecting the new 12V plug
