What does Control Panel say?Roof box in up position. Won’t close. Is pump too hot - 28 in North Wales . Local recovery on way so they can look through vw book as well as me. Any advice today much appreciated in advance
Has roof sagged at all? ours was dropping enough for "intermediate Position" to be shown on control panel & roof wouldn't go up or down. In that state disconnecting starter battery reset the control panel to allow roof to go down.Roof box in up position. Won’t close. Is pump too hot - 28 in North Wales . Local recovery on way so they can look through vw book as well as me. Any advice today much appreciated in advance
Remove fuses 5,6,7,8 wait 30secs and replace.Roof box in up position. Won’t close. Is pump too hot - 28 in North Wales . Local recovery on way so they can look through vw book as well as me. Any advice today much appreciated in advance
Hi WelshGas, says intermediate position and is sagging on right. Lights don’t work in roof boxWhat does Control Panel say?
Do the lights in the roof work?
Pull the fuses as indicated.Hi WelshGas, says intermediate position and is sagging on right. Lights don’t work in roof box
Sounds identical to our problem.Hi WelshGas, says intermediate position and is sagging on right. Lights don’t work in roof box
This guy is asking for a diagram???Pull the fuses as indicated.
Where is battery in rear?This guy is asking for a diagram???
Hi, thanks for this. Where is battery in rear?Sounds identical to our problem.
if you have a 11m spanner I found disconnecting the starter battery quicker & easier than trying to find the right fuses.
If you use VW assist, the AA chap that turned up for ours had instructions from vw to disconnect all 3 batteries, so prepare to empty the boot space!
Also if its sagging, its important to put the roof back up to the full extent before lowering so you have half a chance of it getting down reliably evenly.
Roof box down. Cancelled last night away off straight home. Cali in for warranty issues Weds. just called to add roof box. What do they need to do in workshop? Cheers again allThis guy is asking for a diagram???
Mine needed software update & new hydraulic rams.Roof box down. Cancelled last night away off straight home. Cali in for warranty issues Weds. just called to add roof box. What do they need to do in workshop? Cheers again all
