Are you still under warranty or are you still a member of VW Assistance?Hi. Please help. When I lower the roof the indicator on the central panel continues to show the roof up symbol. I have checked there are no obstructions and visually the roof looks properly down. Any suggestions. Thanks.
Have had this once. Just put it back up and down again. Would just be a sensor glitch. Rectified itself.Hi. Please help. When I lower the roof the indicator on the central panel continues to show the roof up symbol. I have checked there are no obstructions and visually the roof looks properly down. Any suggestions. Thanks.
Or reset the CU to clear errors stored.Have had this once. Just put it back up and down again. Would just be a sensor glitch. Rectified itself.
Thanks. How do I reset the CU?Or reset the CU to clear errors stored.
And always make sure you hold the up/down button until the pump stops making noises, do not release it when you think it is down/up completely, only when the system thinks so and stops. A common error. The last bit with the extra loud noise is when the lock is pushed in place.
Check Control Panel Diagnostics.Thanks. How do I reset the CU?
Thank you. I will give this a try.Check Control Panel Diagnostics.
Control Panel Off and wait 30 secs
Control Panel On
Press and Hold R lower button and then press Control Knob for 5 secs.
New Hidden Menu . Scroll to VW Diagnostics.
If there are any codes shown, take note and then Reset/Clear.
Return to Main Menu.
Switch Off Control Panel using L lower button. Wait 30 secs and Switch On.
Try Roof/Heater or Fridge
