Roof wont open and interior light is gone
L
louipedersen
Copenhagen
T6.1 Ocean 150
Hi everyone,
I have a California Ocean 6.1 from 2020. My problem is that I can not open my roof and the control panel is saying "the roof is jammed or blocked". At the same time my interior light won´t turn on. I have checked all of the fuses under the left front seat, but they all seemed to work. I have also tried to reboot the control panel by removing a fuse which caused the control panel to switch off (don´t know if I rebooted it by doing that). My batteries are full charged according to the control panel.
Have any of you tried something similar to that and do you have any suggestions what to do? Where do I find a fuse diagram for the California 6.1?
Thanks for your help:thumb
Best regards
Loui
Have a look at SH13 under the front left seat. Should be 30A.
If no joy try the relays (they can be swapped)
If still no joy maybe an OBD reader to look at the hall sensors and browse error codes on J608?
And before you get carried away pull and replace the 4 fuses described in the California Supplement. This will reset J608.
