![Matthew Barber](/data/avatars/m/15/15279.jpg?1515250606)
Matthew Barber
Hello All,
The rear sliding door of my 10 Plate Se has developed an annoying habit of refusing to unlock. This is particularly apparent after cold or wet weather. The rest of the Van unlocks but the sliding door refuses to budge. Neither the outside
or inside handles can unlock it. Repeated presses of the unlock button on the keyring will eventually result in the door releasing but it is getting worse.
I’ve noticed that when it does unlock, there appears to be water pooling in the sill under the sliding window.
Today I’ve removed the door panel to take a look as I was worried water was making its way into the door itself. Thankfully it isn’t. There doesn’t appear to be a drain in the window sill so I’m not sure where the water that collects there is supposed to go.
I’ve sprayed the mechanism by the handle with wd40 and it appears to work although time will tell as the weather is now good. One press of the unlock key opens driver door, a second press is needed to open the slider. If the van is locked twice in the fob then one unlock press opens all doors. Does this sound right?
![IMG_8605.jpeg IMG_8605.jpeg](https://vwcaliforniaclub.com/data/attachments/123/123216-c2b99bbdbd32492750aff687e22f5dda.jpg)
![IMG_8606.jpeg IMG_8606.jpeg](https://vwcaliforniaclub.com/data/attachments/123/123217-874f94946b59a607b01b44945e3e74cc.jpg)
