Software updates
I’ve not paid for anything and I get them! Assuming you mean the “media pro”?
Yes correct….so does It happen automatically? I have media pro but only the free connect app
be warned our dealer kept our cali for 2 days due to *trying* to update to the latest software versions.. its quite troublesome apparently
Thanks @zippster Mine is rebooked in (with a loan vehicle) and i’m anticipating they’ll have it for a day or two. It’s a strange issue in that it only affects the non-retention of a couple of things in the on board computer memory (SatNav favourites & Overspeed warnings). If it was hardware related then i’d expect to see other things affected. However, if it’s software then i’d also expect other owners on here to have the same ‘fault’.
Anyway, it doesn’t affect the use of the van, it’s just an irritation. I will get it resolved even if it takes the full 5 years of my warranty :) :)
I am also still getting the screen breakup issue, now finding it does it with both Google and Apple maps. I don't think it is signal related @GrumpyGranddad, because it happened this week in London on full fat 5g. Also it resets immediately if you switch out of Carplay in the main menu and then straight back, but then eventually goes wonky again. Its bloody annoying tbh, not least because Carplay navigation worked absolutely seamlessly for over a year before this started happening, and its still fine for other functions. Mine also repeatedly forgets speed warning settings as well, which is inconvenient but relatively minor.
I have a problem with the update. The system information screen shows that there is an update, but when I click on the Update software button, it does nothing and it shows no updates. What can I do to update the software?
Have been told these main dealer updates usually take anything from 4 hrs to 8 hours or in some cases overnight ?
Possibly why you normally have to ask yourself to be done at a service .
On the plus point was also told they are free of charge.
Was also told there are only 2 types of updates ?
1 for the Leisure Battery
1 standard update via Radio
Out curiosity how many of these updates normally come out over a 12 month period ?
Have experienced the same as you but am sure that something automatically updates. Had a bigger OTA update on Friday - 2 stage process 1. Software download whilst driving and 2. Installation whilst the engine was off (which took 30 minutes). Not sure what was updated but did notice that all the radio station logos had changed. I also get map updates over the air fairly regularly.
Yes I had exactly the same as you , last week
Apparently latest version update is a V Number ?? 01008 since April 2022 , looked on lots images people sent in, can't see a V number ?
Can anyone explain were latest version number should be ?
Also what actual other figures relate too ??
