DonGraham
Hi again, my GC680 has factory solar fitted, which does appear to work. The leisure battery shows 100% on the internal display panel when parked on the drive, and with a voltmeter across the battery I can see an increase in voltage when the sun is out.
My query is, while draining the water using the taps in the electric cupboard a week or so ago, I noticed a flashing led on the Votronic MPP250 unit. The LED flashing is "MPP" and according to the instructions it says "Battery Protection". I have had a look a few times since including when quite dark, and it's always been the MPP led flashing. I have never seen any other LED's such as "Batt. Full". Is this normal? I've checked the DIL switches and they are down down up down, which seems correct for a lead Acid / AGM battery.
The instructions describe 2 types of flashing MPP LED. "Flashing" and "Short Flashing". Not sure what mine is, but it is a flash around ever second, ie count 1001, 1002 etc and it flashes in time.
Any advice appreciated...
TIA
TIA
