Stop water in grand cali 600
N
nuno ribeiro
Faro, Portugal
Grand California 600
Someone can help?
I arrive in the camping, and everything ok.
Suddenly the water stops, the tank are full but the water dosent flow
Help please
Cowbridge
T5 SE 180 4Motion
Someone can help?
Help please
No idea if the Grand has similarities with the California, but check the following.
Does pump run with tap on? If not check fuses. Normally a 5 or 10 amp fuse. No idea where they are found on the Grand.
If fuses OK, check under sink, there should be 2 wires to tap, follow wires and there should be a plug. Unplug connector and bridge with a paper clip or similar the 2 pins on the connector that is not on the wires leading to tap. If water still not flowing then probably the pump.
Simple trick, open tap and blow down the tap spout vigorously to clear any air lock. If still no water then remove pump from water tank. May just be jammed or may need replacing.
N
nuno ribeiro
Faro, Portugal
AlanC
AlanC
Traveling
Bristol
T5 SE 180
I believe there is a known issue with the Grand's water pump.
Lizzie and Sean of 'A Bus and Beyond' fame took a VWUK loaner down to Gibraltar earlier this year and had an issue with the in-tank water pump on this trip.
Have a look at their web site.
Alan
Cowbridge
T5 SE 180 4Motion
Someone can help?
Help please
Have you been able to sort the problem?
Campnorth
Finland
Greetings from Finland! We had same issue, but the "other way around". Our waterpump turned on itself and lived all own life. There was no effect by turning faucet on and off - waterpump stayed on or off regardless. So problem was in the kitchen faucet itself. It gave wrong electric impulses to the waterpump. Our dealer changed all faucet by guarantee repair. New part is a little bit defferent, makes a little on/off click sound and have a new part number/manufacturer. Hope this will solve your issue also. Regards M&T
