MrShaz
Hey WelshGas…the van is probably used very infrequently these days on daily trips as I work from home and cycle into the office on the odd occasion I am in. I have just run an aircon cleaner through so will see if that helps. Initial thoughts centred around the wind out awning which was left wet during Glastonbury and only remembering a few weeks after (post heat wave) but that was wound out and cleaned (unless mould is in the mechanism) The awning is external so that wouldn’t leech into the van interior would it ? I would struggle to see how it’s anything engine related as you say as the smell is there with Pugh the engine being on.As above, But, do you use the AirCon regularly?
If not has the system been sterilised?
