sidepod
- Messages
- 6,320
- Vehicle
- T4 PopTop
As the title says, fridge job description failure.
I'm pretty sure it's the control box but I'll throw it open to the panel for your ops.
Fridge shows as on when selected from the over head contl pnl.
Compressor motor runs. Fridge doesn't cool
I stripped it out last night and I have a healthy voltage at the unit.
Compressor is running but it doesn't sound as if it's doing much work.
Freon gurgles as it should.
Thermostat is good. I connected in a known good one that made no odds.
Diagnostics. When interrogated for load (4.5A) the fridge shuts down!
This is what makes me think it's the electronics box.
I removed the control resistor from the fridge unit and linked the stat directly in which should cause it to run. Nothing.
I know the motor has a low speed drop out at 1850 rpm so it's obvs running at least this fast.
This is or isn't enough to cool ?
There is an option to connect a led across pair of terminals and check diagnostics by observing various flash patterns. I'll do this.
I've ordered a new control box. Fingers crossed.
