I
Ian Reynolds
Hi, I have the same problem as a number of others have reported over the years with my interior cab and footwell lights no longer working.
I have checked all the fuses with my AVO meter and they are all good, so it's not fuse related.
Moving the central interior light switch to permanently on makes no difference, I've even disconnected the battery but that doesn't reset anything.
The illumination lights in the switch work do work though, so there is a side light power feed and earth to the unit. I know the earth is shared and a separate feed powers the illumination lights.
I have recently looked through the wiring diagrams and interestingly there is a mention of a "Entry and Footwell Light Relay (J348)" on page 804/1 and it says it is located "under the dash panel (centre, under the fuses)" . Pic attached from manual.
Now, I've looked and looked but I cannot see anywhere that there might be access to an area "under the fuses", I've googled and searched the WWW but cannot find any video's or articles that show how and where this might be!?!
Do any members have any clues as to how to access this under the fuses area, under the dash panel?!? From the diagram is seems there is a big relay area there.
I am aware of the engine relays under the battery, but that is located under the bonnet and not the dash.
Any info or pointers would be much appreciated!?!
Ian
Ian
