Mike Frost
2009 130 T5 SE - "BARBARA ANN"
Dear all,
Working through our autumn snag list - We've experienced, over the last 12 months-odd, that after raising the pop up roof, sometime between the 2nd and 4th day, the driver's side of the roof begins to sag. The (very) intermittent automatic 'retensioning' of the roof sometimes fixes it, but more often not. If we lower the roof most of the way down, and then raise all the way, to the end of the purging cycle, when the tick appears on the screen, it's fixed again, but only for so long.
As the roof raises all the way every time, I'm not thinking that it's a pump issue, or indeed a hydraulic fluid level issue. Rather, I suspect that a washer/seal within the slave ram has compromised integrity, and that over time, the fluid is bleeding past it, allowing the roof to sag.
Am I (probably) on the money here, and if so is there a fix, short of replacement of the slave ram unit?
Or, is this an early warning sign for a catastrophic failure of the system, requiring expenditure of gazillions to fix?
As ever, I would be deeply grateful for any advice from the extensive knowledge pool on this very erudite forum!
Best,
Mike
Best,
Mike
