356DNA
I filled the water tank today on my t5 SE for the first time since I bought it at the start of the year. Mainly to check everything was working but also to run some milton through the system.
When the tap had run for for a few minutes the water tank a vacuum was created - i noticed as there was a hissing noise from the rear and this was solved with another hiss when I opened the filler cap again. I guess there must be a one way air inlet valve and mine isn't working.
Can someone let me know where the air inlet normally is for these? On the filler cap or somewhere else?
Many thanks
David.
Many thanks
David.
