Minime082
Hi all, so i decided to convert my T6.1 Beach to have the 'A' pillar blinds fitted as they are not standard nor an option in the UK. All parts are available the same as Ocean/Coast models. 'A' pillar trims are straight replacement. The upper fixing mount involves removing the roof centre panel and fitting the mount in place of the blank plate along with x2 support screws. The hardest part is the lower mount on the dash. I had to make a template then cut the square slots in the dash along with drilling x3 holes to fit the spreader rivets once all fitted works a treat.
