Fergie Collier
I have a 2016 and the wind out awning in that year of manufacture had a join in the material rather that one piece. I believe it was a supply issue and it was only a limited number at this build time had the split material?. The problem is it split along the seam where the join is. Tried sticking it, taping it etc but it really needs properly fixing. Has anyone else out there had this issue and what did you do? Can you replace the material, if so is it a DIY job and where do you get it?. Or is it a case of replacing the whole awning unit. Hope all this makes sense and you can assist me. Thank you.
