T6 Beach wheel choice advice
Micka
Micka
Brentwood
T6 Beach 150
Hi all I’ve got a 2018 T6 Beach DSG 150
Looks great but I feel the wheels (16s) let it down on looks (I want to go 18 at least) and the cornering could be improved
I’d like to talk to someone about my options and what the considerations are....I’ve read about calliper issues and load rating etc. Ideally I’d like to speak with someone who can also arrange fitting in my local area (near Brentwood Essex) if possible.
Ideas/contacts welcome
If you have the 150 you should already have the bigger break set up anyway.
18s - they do a couple of options. Toluca or palmerstons but they arnt cheap. Maybe look at some aftermarket options? Wolfrace, BBS etc.
Wheel diameter size won't be a problem when you already run 16s, it only you can't run them with the bigger calipers.
There are so many choices of wheels it a case of finding what you like. Just make sure they are load rated and the tyres are load rated.
I currently run 18" Riva SUVs.
Thanks I like the look of some of the Wolfrace. Is there a sure way of checking what will fit?
