Andy Cook
- Messages
- 13
Thanks secret lemonade drinker, Yeomans want £144 per hour for a diagnostics check in 25 days, suggestions for local VW mechanics with correct testing equipment gratefully received.Probably an implausible signal from an abs sensor but you will need an obd reader to verify
Any VW specialist will have the right OBD reader, if you were in Lake District I have one, I did a caddy ABS sensor last weekend for my Father. There is an independent in Barnstaple and in Exeter.Probably an implausible signal from an abs sensor but you will need an obd reader to verify
Had exactly the same problem a few months ago and booked the van into Birmingham van centre and abs sensor in rear wheel replaced which solved the problem. Luckily bought 5 year extended warranty when van purchased so work carried out under warranty- expires end December this year. Hope this helps.
Thanks for your reply, my extended warranty ran out a few months ago, for your information, although I had warranty with VW they would not accept that the failed roof sensor was covered and wanted £3,500 for the repair, this forum recommended Richard Milton of Kernow Transporters in Marazion who repair this fault for £275. He also suggested that my recent fault was an ABS sensor and I have booked a slot with him to repair the fault. I’ll post the result.Had exactly the same problem a few months ago and booked the van into Birmingham van centre and abs sensor in rear wheel replaced which solved the problem. Luckily bought 5 year extended warranty when van purchased so work carried out under warranty- expires end December this year. Hope this helps.
Hi Wilbur,Here is another option
South West VW in Barnstaple. Independent VW garage 01271 379549.
Thanks Dave, Brixham is certainly closer but I’m booked in to Kernow Transporters on Tuesday.TMVR in Brixham will sort this for you. I had it last month. ABS sensor as others state
