Tailgate hinges on a Cali
FredFlintstone
FredFlintstone
West Midlands
T5 SE 180
Hi Folks, our Cali is not parked locally so I can't check myself.
Need a little help.. is it possible to directly access the tailgate hinges on a Cali, or is there trim over them?
It looks like there's major stripdown to access the internal hinges? So am hoping that the external hinges are accessible?
I have tried a quick internet search but couldn't see myself.
Big thanks
Not sure I understand what the question is ?
the hinges to the tailgate are attached to the top of the tailgate door.
They are fully accessible when the tailgate is open.
there is no trim over them , they are painted body colour
not sure what you mean by the “internal hinges” ?
Edit: are you referring to removing the tailgate hinge ?
Thanks, you've just answered my question perfectly TBH.
So with the tailgate open, there's unimpeded access to the hinge & hinge fixings.
Just what I was hoping to hear!
The other side of the hinge (the body mounted side). I think these are 100% covered and require major teardown to access.
What is it your trying to do / achieve?
Well.. After fitting an OEM bike rack I find that the tailgate is misaligned (tailgate clearance to tail light smaller on the left). Meaning bike rack clamp is too close for comfort on the LHS.
I'm going to explore shimming the LH hinge in the tailgate.
Rack might just need a wiggle. Mine looked like it wasn’t right, but just needed a small shift.
Look in the resource section I have posted how to adjust the tailgate
here is the link
i have fitted many bike racks and they do vary sometimes the sealer under the edge is thicker one side some vans have vey little sealer at all the racks tend to fit better on those with an equal gap between the tail lights
Before you go for the nuclear option (realign the tailgate) check the rear light seating , it sits on a couple of plastic pegs attached to the body work (behind the light unit) aligned with the “u” shaped fixing in the rear of the plastic light casing, undo the fixing screw(s) and remove (visible when tailgate lifted), lift the light unit to the side it will come off the peg fixings , it will be retained by the electrical connection.
Check the peg‘s and corresponding U‘s, clean if necessary , refit, push down gently until the light is seated correct on the pegs (to see if the light unit will move downward) , re secure the screws.
The light unit moves sideways to remove it from the fixings
here is the link
Yep, have seen this before. However guessing (and it is a guess because I've not been able to properly investigate) that these are completely inaccessible?
Correct the fixings are behind the internal trim Etc.
realigning the tailgate is not for the faint hearted, I would explore every
other option First.
Yep, exploring options currently
What Is the gap at the bottom of the tailgate like I.e. parallel to the bumper etc , is there any obvious gap issues anywhere other than when the bike rack was fitted which seems to have highlighted the issue?
as mentioned above check the thickness of joint sealant is not affecting the way the clamp seats on the tailgate.
Before you go for the nuclear option (realign the tailgate) check the rear light seating , it sits on a couple of plastic pegs attached to the body work (behind the light unit) aligned with the “u” shaped fixing in the rear of the plastic light casing, undo the fixing screw(s) and remove (visible when tailgate lifted), lift the light unit upwards and it will come off the peg fixings , it will be retained by the electrical connection.
Will thoroughly check this on the weekend
Try taking the lights off, fit the rack, then reattach light cluster. Might give you a bit more leeway. Just close the boot very carefully first time in case light fouls on the rack.
Video - Barn door van , but same principle.
Gapping at the lights (tailgate to top of light lense bigger RHS to left). Gapping between tailgate & bumper skin RHS is greater that Left. Gapping between lower edge of LHS rear light lense is same as on RHS.
Will be rectifying this weekend if all goes to plan!
