Califorian
Hi, I have been posting on the General Forum hoping to get some useful info on fitting towbar to a 2015 Cali 180 SE that has towbar prep ID7. I suspect I am either missing the obvious or have the wrong expectations!!!. I was hoping that once removing the lights and bumper etc it would be obvious that a harness was available to connect to. The Towbar fit (Provided very quickly by PF Jones) went smoothly and took about 1 hour. however the wiring has come to halt until I find out where the connections are . With towbar prep I don't expect to have to run cables under the vehicle to the passenger seat, dash and engine compartment. Indeed the harness provided by PF Jones (13 pin dedicated wiring kit 05/2012 Westfalia part no 321652300113) is quite short and only has two connectors. The instructions provided state the connectors are behind the passenger side internal rear wheel arch cover. Although I can get part access to this area it would probably require the removal of the wardrobe etc. This doesn't seen to tie up with other comments I have read where it is stated the wiring with tow bar prep is quick and only takes 45 mins.
Any help would be welcome, good news or bad news is acceptable. but there must be someone out there who has experienced the same issue .
thanks in advance of some words of wisdom and support
