My T5.1 Westfalia detachable tow bar has a weight limit of 100kg. It is marked on the label on the underside of the frame behind the bumper.Does anyone know the towbar weight limit on a T6.1 or how to find it, does it depend on the model/towbar fitted? Caravan dealer said need to check towbar limit will need 120kg?
Ditto on mine.My T5.1 Westfalia detachable tow bar has a weight limit of 100kg. It is marked on the label on the underside of the frame behind the bumper.
Alan
Thanks will try this out!!Ditto on mine.
In practice, if the front wheels of the van lift off you've put too much on the tow bar.
