WaikatoCalifornia
Hi all, my 2022 build T6.1 Ocean came with an inverter plug under the driver’s seat (I’m in NZ, so my steering wheel is on the right, same as the UK). The plug is designed to take both EU and UK plugs, but a UK plug never seems to stay plugged in or pops out with the slightest bump or movement. Is anyone else having this issue, or should I refer it to VW? The plug is also installed in what I would consider to be an upside configuration for the UK (earth is at the bottom), but I guess that’s common on split EU/UK plugs, and allows for the left-hinged safety cap over the plug to open away from the handbrake. Just interested really, if it’s a common complaint/design fault and others are having the same issue, I’ll probably just use some 3M velcro strips on the plug and socket. Cheers.
