Kmann
Iben & Henrik
Sorry for the long post ;-)
As new owner I now have been on this forum for a short time, and I did not take long for the daily visits to become a pleasant routine ;-)
Due to winter, jobs, getting to know the car and a ski accident, we did not manage to make a trip with the car yet, but we are preparing summer holiday to Corsica and Sardinia amongst other small trips, the first next weekend.
After reading a lot on this forum, also about living unplugged I wanted to test the car in the driveway, and besides describing my findings, I would be very pleased if you would share your experiences upon the following. Is the normal behavior?
Im still not sure I get the Ampere and Volt thing … ;-)
So here comes ALL the questions:
I use the car as my daily vehicle. So I guess regular plugging/charging is nothing I should make a concern about – is the right? I thing the generator will charge all thats needed?
The test i made (see details below). Is this to be considered normal? I have read that people have been of the grid 2-3 days not getting under 40%. I am running as low as 50% in 19 hours.
The cooler has its struggle to start. Maybe due to the cool weather, as i read. But the manual states one should be alerted using the cooler in cold weather (I guess below zero), because it could freeze the content. That does not fit with the issue, the cooler not working because it is cool weather (3-10C). My cooler did not start on level 4, after I turned it to max, and back to 5 it was running. But never came lover that 6C. Is that normal?
My heater goes tick, tick, tick … endlessly. Is that a normal? Or something I can change?
After end the control unit shows 12.1 V / 90% / -0.6 A BUT after restarting the control unit it showed 12.1 V / 50% / -0.6 A. Quite intersting the reading is not updated? Any discovered that before?
I am not sure how much it I shall pay attention to the 50%. But is this a normal behavior after 19 hours in cool climate?
Test details for the nerds
Outdoor temperature 7,5C
Time: 16:32
Arriving home display says:
12.8 V / 100 % / -0.2 A
Turning heater on (4) display shows:
14.6 V / G / 1,4 A
Turning cooler on (3) display shows:
12.1 V / 90 % / -10.4 A
It contains some beers, and water bottles
Time: 19:10
Tjekking. The car is nice warm inside.
12.4 V / 90 % / -0.6 A
The cooler is 10C and not running. I regulate to (4)
Time: 21:10
Tjekking. Still nice warm car. Probably to warm for sleeping ;-)
12.4 V / 90% / -0.4 A
The cooler is 10C still not running. I regulate to max, and it turns clearly on. I turn it down to (5) and it stays running.
Time: 23:20
Tjekking. Heater still running (clicking tick, tick, tick)
12.3 / 90% / -0.4 A
Cooler still running, now 9C
Keep the things running over night
Time: 09:20
Tjekking and finishing the test. Outside temperature is 9C
Car is still nice warm. Cooler is not running but 6C - I think the thermostat has shut down?
After shutting the cooler and heater. I shot down the control panel and turned it back on again. Then it showed:
Time: 16:32
14.6 V / G / 1,4 A
Time: 19:10
Time: 21:10
Time: 23:20
12.3 / 90% / -0.4 A
Time: 09:20
