Upper cupboard squeak
  • Thread starter IsThisNameLongEnough
  • Start date
I
New Zealand
Grand California 680
Hi all,
We have found when travelling we have a really high pitch squeak inside the cabin.
Have narrowed down to the rear upper cupboards, i think from the plastic catch on the aluminum.
Anyone else had this/found the best way to solve?
Cheers
Just found this thread, I've been plagued by high pitch squeak, my engineer son went in the back whilst I went over uneven surfaces and confirmed it's something to do with the aluminium rail. I'm unsure if it's catches or the way the cupboards are mounted.
The catches have a good deal of adjustment. Try tightening them to see if it helps.
sorry, should have said the hinges have a good deal of adjustment.
Had the same issue…after applying cloth tape to the plastic vertical posts and the c shaped bit of plastic on the door I have silence….you would’ve believe the tremendous feeling of well being when I finally cracked the problem (spent weeks applying cloth tape and silicone spray literally every where imaginable). Hope you get to experience the joy soon!!
Do you have location pictures.
Just popped outside and taken a few. I did all the catches top and bottom for both wardrobe and rear cupboard… not sure if needed them all but at least one of them did the trick.
