Is this essentially the same as what come with the t6.1 California?You need one of these, it's just a tap.
DO NOT use one of the blue screw on regulators. The van already has the regulator.
Exactly the same - the GOK valve from the club shop - or the one pictured on amazon for about £9.00 from memory, one of the hoses supplied with the van has the correct thread to fit.Is this essentially the same as what come with the t6.1 California?
Yeh that's right so just need gas for cooking, ill have a look into this, im assuming they are no heavier than a 907 if compositeThe 907 is handy as its light & leaves most of the gas locker empty. I assume you have Diesel heating & water?
I would however recommend the use of one of these gaslight bottles, the bottle weighs very little & you get almost 4 x the amount of gas as a 907 for 20% more refill cost.View attachment 110316
empty 907= 3.7kgYeh that's right so just need gas for cooking, ill have a look into this, im assuming they are no heavier than a 907 if composite
