volts indication
alter
alter
I'm trying motors
Italia
Sorry for the trivial question .... i volts indicated on the panel are those of the leisure battery, right?
And l 'amperage displayed, positive or negative, refers to the current at that time charged from the charger or consumed by the various services on board?
regards
Yes that is right.
The control panel only indicates the voltage and current flow of the two leisure batteries installed in a SE or Ocean California. The engine battery is independent of leisure system and so these measurements do not apply to it.
Alan.
Ok, but the panel has in the menu "hidden" the words "secondary battery".
If you turn on the second l 'indication battery is related to that of the engine?
Otherwise, as can give the voltage of one of the two service if they are connected in series ...
To clarify: what is the first battery and what is the second?
thank you and greetings
