VW bike rack
Celia Vanchez
Celia Vanchez
Jersey
T6.1 Coast 199
Does anyone know the total payload for the VW bike rack? My wife is contemplating buying an electric bike. I have one already, a Specialized Vado SL 4.0 so her choice of bike will be very important if weight turns out to be a deciding issue
Mine is for a T6.1 and if I remember correctly it carries 60kg.
Verzonden vanaf mijn iPhone met Tapatalk
I assume you mean tailgate hanging carrier and not a towball mounted one? If so, the overall weight rating is 60kg, but each rail is rated at 17kg. That is probably not enough for electric bikes, you should look at towball mounted ones (assuming you have a towball) that have higher load ratings.
Even with the battery removed you are likely to exceed 20 Kg. My newly acquired electric MTB exceeds the length and width of the rails on my Atera Strada D3, so keep that in mind if you contemplate getting a new carrier.
I think you will have 2 issues.
1) e-bikes will be difficult to get on the rack from a weight/balance perspective. Particularly if you are on the shorter side.
2) With that amount of weight you are at risk of bending the tailgate.
When considering e-Bikes, a tow bar carrier is definitely the way to go.
If you go Vado SL route for second bike (as you should, imho :), you should be fine as they're around 15 kg each. If you're ok with getting them on and off, of course.
Thank you. I was thinking of going the same route as my bike. I wasn’t’t aware they were only coming in at 15kg although its ‘light’ looks was a factor in decision to go for it. I’ve had no problem getting it on the rack so far but…….the years are rolling by
Y
YawpedalMiska
Y
H
Hogie
H
Neilsimpleflying
Accessories For Sale VW bike rack
rupertpoon
rupertpoon
