Water filler hose leak
3wolves
3wolves
Bristol
T6.1 Ocean 199
My 2019 Ocean is in for some bodywork after a minor bump and they have noticed evidence of leaking around the flexible hose of the water filler, photo attached. Rather than try to reseal the existing join has anyone replaced the flexible hose with something more suitable, the ribs on the hose are always going to make a good seal difficult. The hose is 40mm internal diameter and any help would be appreciated
Mine was leaking too, the jubilee clip on the tank side wasn't
fixed.
I managed to screw it up tight and since then I've always made sure that
when I fill the tank, the hosepipe goes beyond that connection.
fixed.
Thanks for that Westfalia, I guess new sealant and a tight Jubilee should do it
