Water inside rear doors.
G-A-R-Y
G-A-R-Y
Bristol S/W
Grand California 680
Drips of water from the rear doors, I removed the small rubber bungs to allow it to run freely. I guess it comes in around the window??? There is no other way it can get in.
There was a facebook post but I can't get back to that.
Hi Garry
Do you have this problem when the doors are closed?
If yes, it may be a leak from the 3rd stop light seal (see if there is water on the bottom of the rear cupboard). Problem Solution: VW TPI 2067615
If water appears when you open the doors then see this improvement:
Right door mostly, water comes in via the exterior handle.
Within a month of my van being on the road had over an inch of water in the right rear door. First job was to remove the bungs from the bottom of both doors then spray the bottom of the inner doors with Tetroseal.
The bottom of the side panels are prone to a similar problem because the factory left all possible drain holes blocked with expanding foam sealant! Converters who know of this poke holes through that sealant before working on the vehicle.
Buenos días,
Sigo teniendo filtración de agua por la luz sobre la mesa a pesar de haber sellado la luz de freno de techo, taller VW, podría ser de la claraboya del baño ?
Gracias si alguien me ayuda
Espero que el traductor haga bien su trabajo.
Gracias
I have the exact same problem in the drivers rear door.
Posted on the UK GC group, as the suspect is the rear window, i have sometimes emptied about half a pint.
When i get round to it i think removing the trim and lining the inner bottom of the door, or looking into the possibility of removing the rear window and sealing it correctly.
I guess it can only be the window, I think it's quite difficult to remove that panel.
Buenos días,
Gracias
Buenos Dias
If you have water coming in by the table there it is worth checking to see if the silicone bonding the fibreglass roof to the metal crafter has deteriorated. Like some others we are about to have ours replaced by VW as the tiny cracks in the silicone lets water through. In ours the water comes in to the toilet cassette cupboard and out through the front cab grab handles
I just had my rear stop light on my vw done Gary, seal had gone and had drips from where the seats slide into where they are stored in the tail gate. Vw were going to charge me £450. I payed £80 for parts and labour with someone else.
Efectivamente, como dice Plataforma 1, el agua entra por la silicona agrietada, hicimos una prueba sencilla con la manguera y se vio
El vehículo está en el taller VW para solucionarlo
Muchas gracias
