mikec45
When our ocean is facing downhill, we get water that appears to drip from somewhere on to the edge of the headlining material and then spreads across to the grab bar above the door whenever it rains. The heavier the rain, the water it gets (photo below is a mild example).
I’ve looked inside the headlining, and opened the roof and no sign of any holes or obvious entry points. Felt drain pipe and bone dry. Thought it might be coming in via top corner of windscreen so sealed that up but made no difference.
Any ideas or thoughts? TIA
