W
Wavefury
Hi all,
Had our GC600 for 2 years now with no real major issues. Last week though the water system seems to have shut down completely (no water from kitchen, bathroom, or rear shower). There is no sound coming from the pump. Fuse is OK, and yes, there is water in the tank!
....which leads me nicely onto the second problem (or maybe further symptom).
The display panel is showing that the water tank is 645% full, and the waste tank is 201% full, but the battery is sadly 0% full, which considering it's plugged into an EHU, and the lights and fridge all work ok still when unplugged would suggest otherwise!
I've pulled fuses, turned the big red knob off and on countless times leaving increasingly longer times before turning back on, shouted at it, and only haven't gone the full Basil Fawlty on it as, well, its an expensive vehicle!
When I do turn off the red button, the display will initially show me having 0% water in both tanks for a variable period ranging from about 30 mins to 2 days before reverting to the 645%, etc. It also reports 100% battery initially too.
I've checked the visible connectors above the water tank (under the mattress panel), and they all look OK.
I've tried swiping the T on the panel to get into the service settings but that seems to have stopped working for me too. The panel is otherwise responsive.
Has anyone come across this before, or Know of anything else I can try?
Cheers,
Andy
Cheers,
Andy
