Thank you, seized it was, now working fine!Hi, if it has not been used for a while it may be seized up. I truck I use is to put enough warm water in the tank to cover the pump. Then try turning it on a few times, even leaving the switch on for 20 seconds or so. This may help free it out.
Glad you got sorted.Thank you, seized it was, now working fine!
