Weird squeaking when I turn the engine on
RobertCalifornia
RobertCalifornia
Llantwit Major
T6.1 Coast 150
I’ve only had the Coast 6.1 since February but when I turn the engine on it has started to make the kind of noise I used to expect on our (now defunct) 15 year old Bongo!
It is a weird high-pitched squeaky noise that you can hear in the cabin and sounds like something is loose, and rubbing against a block of polystyrene.
Any thoughts on what this might be?
Did you see anything obvious when you looked under the bonnet?
Thanks @sidepod. As may be obvious from the level of technical language in my post, I am pretty ignorant about how the engine works! I haven’t looked yet because I don’t really know what I should be looking for - any pointers?
Thanks for your help!
Probably a belt. Call VW assist and they can look at it at home.
Failing that book it in with your dealer.
I suspect VW assist will be quicker though.
I agree it sounds like it could be a belt is loose and the squeak is the sound of it slipping on a pulley. If so it’s most likely a very easy fix.
Belts quite often sequel for no apparent reason. I have heard that a quick, note quick, spray of WD40 onto the belts makes it go away. I have never done this by the way.
I think thats a bad idea, it might stop the squeak but increase the slipping! I have never heard of that being the solution - new belts shouldn’t slip if they are adjusted correctly.
As @Wildcamper says that’s not a good idea. The belt is an alternative to a chain and should not slip - don’t oil it!
Does it disappear when the engine is warm?
If so then probably a slipping belt.
Either way, VW Assistance should sort it. After all you've paid for the service.
the belts are tensioned automatically with a spring loaded tensioner so i doub't the aux belt is slipping. as said that WD40 idea i reckon is a wind up. i had a squeek on my old golf and that turned out to be the alternator clutch pulley failing. i only found the source of the noise when it finally failed.
With all the rodent attacks we read about, the squeaking could be a nest of mice. Sorry :)
Put your head under the bonnet
does the sound appear to be coming from the near side or offside ?
