Visit a Public Weighbridge. Then you would get an accurate measurement.Hi all- I’m attempting to find out the weight distribution of the van so that I can test a theory for lifting. Does anyone know this information?
Many thanks!
John
Park the front half on and weight it then park……..well, you can probably work out the rest.
Why would it matter? The two jacks are not linked (apart from the hydraulics). As long as the weight limit isn’t exceeded?
I’m curious about why you would need to lift the van sideways?
The max axle load data plate in the engine bay would give you a rough idea.
Normally on the door pillar, a black sticker.I shall have a look!
Yes higher running gear weight but I think it could the same maximum as yours. I'm just closer to the maximum, so we have to be very careful not to overload.Thank you for that- I’m guessing the rear axle on yours is going to weigh more due to the drivetrain. I’ll go have a look at mine.
has anyone pointed out that at the back there is a a big difference between left and right side, due to the kitchen, fuel tank, add blu tank etc. all being on one side.So with 3/4 fork in the tank and an empty water tank and me out of the van the weights come in as follows:
Front 1360kg
Back 1240kg
So that is 53:47 ratio!
I was ignoring that one.has anyone pointed out that at the back there is a a big difference between left and right side, due to the kitchen, fuel tank, add blu tank etc. all being on one side.
My one is likely due for suspension refresh and probably more when I get under there. I don't enjoy working under vehicles with just jack stands whilst heaving away at things.Im still not understanding why you need to lift the van? In 15 years of owning one I’ve always managed with the 3ton trolley jack/axle stands combo. Again, probably over simplifying it.
True - I've not reached this cost/decision lightly. But I have two other cars that I also work on so ROI is roughly 2 years or less. Cheers for the input on this - it's most appreciated.Ok fair enough. The cost of the Quickjacks buys an awful lot of labour? Hey ho.
