Oh, I thought you just spray it into the air tube and it makes the van run rough on idle for a second each spray?You have to remove the egr valve and clean the internal areas loosening the tar black residue with the spray you have bought, it is a very dirty job and you will be black for weeks afterwards
AI OverviewOh, I thought you just spray it into the air tube and it makes the van run rough on idle for a second each spray?
Or worse you are going to dislodge all that black sludge and it is going to go through the combustion process.....if it doesn't damage the engine then why do we have air filtersAnd if it works after the spray has gone through the engine combustion process may I sell you the Eiffel tower?
