Which 18" alloy wheel
Bubble
Hi
I'm interested in fitting some slightly larger wheels on my 2009 California.
I was wondering if any Vw alloy will fit ? Golf / bora etc.
Would also like to know what tyre size is needed to look in good proportion ?
Do I need heavy load alloys or tyres ?
Any help would be appreciated
Many thanks Chris
Yes, you need to ake sure they are load rated to at least 750kg
Is that the tyres or the alloys or both?
Cheers
i have a T.U.V. APPOVED set for sale with rubber .these were made for the t5 .so no wheel bearing going on you .correct off set etc .see parts for sale .i not seen another set on a t5 in uk yet . :thanks martin
Bubble said:
Hi
i think the vw Tiguan wheels might fit on the 2009 California
rang rover will hit the inside wheel arc plastic when you do a tight turn ..and your wheel bearing will not last long .why do people buy car wheels to go on a 3 ton camper with 97y tyre rating .i will only fit TUV wheels to any of my vws .i will pack my soap box away now :cool :doh
Do you not like any of the VW accessory alloys that are available? Car wheels won't be suitable due to the weight, so would only recommend the correctly rated wheels and tyres.
cheers
cheers
I really like the Ethos Alloy Wheel :).
James
