JDVKTM
The left side windscrean washer (heated) on my T5 only sprays to the right
Can it be cleaned or do I need to replace ?
Thanks for any feedback
What does the R hand one do?The left side windscrean washer (heated) on my T5 only sprays to the right
Just try a sewing pin or needle in the nozzle, probably 2 per side and probably blocked. Should clear with the needle. If not just remove from bonnet and reverse flush or blow down the nozzles.Thanks, the right hand side spray's a left and right stream; the left hand side one only a right side stream
