SimonB
Staff member
Whilst driving through the rain this afternoon a warning light of an amber picture of a tyre with an exclamation mark appeared on the right hand side of the speedo with a ping sound as well.
Checking the handbook we found that it meant tyre pressure too low or fault in the tyre pressure loss indicator, Page 309 of the handbook.
The tyres all looked fine, but I had changed the wheels for winter ones recently. Apparently if you change the rolling circumference of your wheels you need to synchronise the tyre pressure loss indicator afterwards.
In the handbook there is a picture of the button to press on Page 309 it also states that this button is on the Central Console. After two of us searched unsuccessfully for this button for a while, or anything like it, I rang the dealership.
Apparently the handbook is generic and the button you have to press is in different places on different T5s and may also look different.
The very patient, helpful lady went through some of the places it can be located - still found nothing even remotely like it. She suggested inside the glove box, on the end of the dash that you can only see with the door open and so on. She then asked a fitter for some more ideas and he suggested that on the end of the wiper stalk, where you press up or down to select the option on the display, if you press it inwards it goes into a new mode where you can change all sorts of things.
The handbook also says that if you put chains on this can change the rolling circumference and thus activate the indicator.
It might be worth finding where the reset button is in your vehicle, before you need it, as you may have no idea what has activated it should it come on and also no idea how & where to rectify it.
Would be interested in hearing if anyone else has come across this problem.
Simon
Simon
