I assumed that would mark ALL forums read and I don't want to do that?I would use the option further up the screen 2nd line down 2nd option across "Mark Forums Read"![]()
Was going to use a rude smilie but I don't know how it woul;d be recieved on here........ you can take it as read!Are you not keeping up Biker gran?I've only 2861 unread as I type........
Ah but I'm a BikerGran!
NO!
Gran's are never rude ......
often![]()
@BikerGran - I struggled with this for a while. As @GrannyJen says, if you only want to make selected threads as read then you need to go into that thread - then when you click on 'mark forums read' the option 'this thread' appears. Which doesn't if you are on the home forum screen, hence it not being so obvious the function exists.Is there some way of marking forums as read without having read all the posts? It's an option on most forums I belong to, comes under 'forum options' or similar - have I just not found it?
