Agree with Martin. Later model years have 2 or 3 lengths of clear reinforced tape on the inside.If that's what they are called - one of mine has come apart. Is there any way to fix this, as it has to stay flexible? Or is it possible to replace it without taking the whole cupboard out?
Mine does 2012 , was that tape not on in every Cali?Agree with Martin. Later model years have 2 or 3 lengths of clear reinforced tape on the inside.
I'm not sure when it was introduced but I think it was sometime around 2010 or could be earlier.Mine does 2012 , was that tape not on in every Cali?
That should do nicely. At least 3 strips, but as it has come apart already I would put 5 strips.Thanks people - don't know why I didn't think of using tape, I have some grey gaffa tape, standard motorcyclist remedy for anything that moves when it shouldn't!
I would try some malleable wire, garden type , and make a hook bend, about 0.5cm at one end. Pass into the cavity with the bend/hook pointing up or down,at the bottom, and push until the hook/bend is BEYOND the door remnant and then twist the wire until the hook/bend is behind the door remnant and then gently pull out. You might need one wire hook at the bottom and one at the top to stop the remnant twisting in the runners.I have this problem with the door nearest the back.
The split has given rise to two bits.
The bit nearest the back is easily removable by undoing the bottom runner.
The bit nearest the front has slid into the 1" gap between the rear cupboard and the wardrobe.
I can't fathom out a way of getting it out short of dismantling the whole double cupboard unit.
I've tried hooks, gaffer tape and even parking the vehicle on a driver-side slope down at which point the top of the trapped/hidden bit pokes out a few inches but I can't get further than that.
Has anyone successfully solved this problem?
I'd be seriously grateful for any advice from them.
(There was no backing tape on this 2007/8 machine)
Sounds as if the bottom has jammed. Probably needs to be pushed in to release. Pushed in at the top first to straighten up the remnant.Yes WG, it sound like the sensible way but the sodding thing remains jammed when I do it and when I do several versions of it. I can't for the life of me fathom out why. Especially when the top edge of the jammed bit is relatively free.
I am an engineering disaster zone but when my rear tambour door decided to become two a bit of brown parcel tape worked miracles ....
I'm shocked that you don't know the 'rules' for fixing things!View attachment 16441
Unfortunately no help for me - it's not possible to apply any tape to one of the two remnants because it's stuck and inaccessible![]()
I like the silicone version for anything plastic - super slippy.And a squirt of WD40 for anything that doesn't move but should![]()
Not quite the same thing but the two clips that hold the doors closed on the hanging wardrobe side have broken on mine.
Last time it was in the dealers having something done I asked for a quote to fix them.
£3,344.00
Apparently the whole thing comes as one unit and has to be replaced ......
