AlanC
Traveling
While traveling in Spain this year, I noticed that a fellow Cali owner had used a phase reverse cable in his hook up feed. So out of interest I tested my supply socket and found that the L+N were also reversed. This was not the Euro 2 pin feed but a proper 16amp blue CEE plug system.
I got a little worried and pulled every cable I had on board apart to make sure the issue was not my wiring. It wasn't, all of my cables were correctly wired.
From then on I started testing all of the feeds I used before I connected the van to the EHU. 9 times out of 10 there was an error on the supply board which I was able to correct.
The worst case I came across was a site on the North coast of Spain which had large power boxes with 14 CEE sockets on each of them. Only six of these were correctly wired on the one I used.
Now as the Cali is properly designed in Germany this issue should not cause any issues to the on-board electrical kit, but if like us, you have a UK made item plugged in to the 13 socket, then the power switch may be a single pole type and therefore the live may not be broken when the item is switch off, leave the item potentially live.
I had always assumed that the 16amp feeds would be correctly wired, and only checked the 2 pin systems with a phase check plug to make sure I plugged the van up correctly.
Has anyone else come across the issue, or am I worrying too much?
Alan
Alan
